So I am referring when getting on it, like when passing someone at 5,000 plus RPM. Is it normal that when you have completed passing someone and realize you are well over the speed limit, so you take your foot off the accelerator completely and even use the brake slightly for it not to upshift for at least 5 seconds? Every vehicle I have ever had seems like under the same scenario it would up shift significantly faster with a designed minor lingering in higher RPM.
