problem with split screen
annieme
Gleason, WI, USA
I have a 2020 Telluride EX. 2/3 of the screen is the map and the other 1/3 used to be the radio station. I pressed on the arrow way on the right thinking that would expand the left side. But now I can't get the 1/3 back to the radio. What do I need to do to get the radio screen back? TIA
SW MO
You tap the arrow at the far right of the screen to bring in or remove split screen.
When the split screen widgets are open on the right 1/3, you swipe vertically on that part of the screen to move between the available options.
cinthya
utah
I spent about 30 mins trying to figure this out last night reading online everywhere with no luck and this was the first answer that actually knew how to fix the problem and it was so simple!!! Thank you annieme!!!
