I've got 40 years of changing the oil but this is a new issue for me on first Telluride change - a very small leak at oil filter. Filter is STP and I removed the old black gasket and put on new one (red) and tightened to 25 NM (using automatic torque socket). My local mechanic said he had a similar problem and suggested using Kia OEM filter gasket but my local dealer isn't able to sell any parts due to the dealer software ransom ware problem. I tried re-using the original gasket but the leak was worse so now I've got the STP gasket back on. Leak is a very small drop every 2:40 minutes or about 22 per hour so I can keep an eye on oil levels but I need to get this fixed. It looks like either the gasket is the issue (as my mechanic thinks) or did I not tighten it enough (filter cover has 35 NM stamped on it but that's a lot, it wasn't that tight from the factory). Anyone else with this problem? Thanks
