Hello! When I went to look at aftermarket rims the guy told me to make sure getting one with an offset wouldn’t harm my warranty. Anyone have any info on this?
Thanks!
If you go on tirerack and choose the wheels on that site you're relatively within the factory specs. The problem with offset is if you go too far negative you may rub the fenders.
Thanks!
Every wheel design will require a different offset so it's not a one size fits all thing. If there's a wheel that you like post it up here and I can help you find the right size.
