DISCLAIMER: You attempt this mod at your own risk. I nor "kiatelluride.org" are responsible for any issues/problems/injuries/death you may encounter.
Front Parking Camera System for Non-SX Trims
All of the parts I used were from Amazon because I don't like waiting
- Replacement Rear View Mirror w/ built in 4.3" Monitor
- Cheapest I've found on Amazon with Prime. Quick and easy swap. The only issue I have is that there's a blue haze to the mirror.
- Backup Camera
- You'll need a backup camera that has the ability to mirror. This one can mirror and remove it's guidelines.
- Wireless Video Transmitter and Receiver
- You don't need to go this route. I went this route because I didn't want to waste time going through the firewall. The downside is that you get static in your image every now and then depending on the placement of the transmitter and receiver.
- Micro2 Add-A-Circuit
- I got a 10 pack because I am doing other projects. For this project you only need 1 unless you're doing the wireless route, then you'll need 2.
