Kia Telluride Specs
Brakes
  • Brake Type 4-Wheel Disc
  • Brake ABS System 4-Wheel
  • Brake ABS System (Second Line) 4-Wheel
  • Disc - Front (Yes or ) Yes
  • Disc - Rear (Yes or ) Yes
  • Front Brake Rotor Diam x Thickness 13.4
  • Rear Brake Rotor Diam x Thickness 12
Cargo Area Dimensions
  • Cargo Area Length @ Floor to Seat 1 N/A
  • Cargo Area Length @ Floor to Seat 2 N/A
  • Cargo Area Length @ Floor to Seat 3 N/A
  • Cargo Box Width @ Top, Rear N/A
  • Cargo Area Width @ Beltline N/A
  • Cargo Box Width @ Floor N/A
  • Cargo Box Width @ Wheelhousings N/A
  • Cargo Box (Area) Height N/A
  • Tailgate Width N/A
  • Cargo Volume N/A
  • Cargo Volume to Seat 1 87
  • Cargo Volume to Seat 2 46
  • Cargo Volume to Seat 3 21
  • Ext'd Cab Cargo Volume N/A
Cooling System
  • Total Cooling System Capacity N/A
Electrical
  • Cold Cranking Amps @ 0° F (Primary) N/A
  • Cold Cranking Amps @ 0° F (2nd) N/A
  • Cold Cranking Amps @ 0° F (3rd) N/A
  • Maximum Alternator Capacity (amps) N/A
Emissions
  • Tons/yr of CO2 Emissions @ 15K mi/year 8.4
  • EPA Greenhouse Gas Score N/A
Engine
  • Engine Type Regular Unleaded V-6
  • Displacement 3.8 L/231
  • Fuel System Gasoline Direct Injection
  • SAE Net Horsepower @ RPM 291 @ 6000
  • SAE Net Torque @ RPM 262 @ 5200
  • Engine Oil Cooler None
Exterior Dimensions
  • Wheelbase 114.2
  • Length, Overall w/rear bumper N/A
  • Length, Overall N/A
  • Width, Max w/o mirrors 78.3
  • Height, Overall 69.3
  • Track Width, Front 67.2
  • Track Width, Rear 67.6
  • Overhang, Front N/A
  • Overhang, Rear w/o bumper N/A
  • Front Bumper to Back of Cab N/A
  • Cab to Axle N/A
  • Cab to End of Frame N/A
  • Ground to Top of Load Floor N/A
  • Ground to Top of Frame N/A
  • Frame Width, Rear N/A
  • Ground Clearance, Front N/A
  • Ground Clearance, Rear N/A
  • Min Ground Clearance 8
  • Body Length 0.00
  • Rear Door Opening Height N/A
  • Rear Door Opening Width N/A
  • Liftover Height N/A
  • Cab to Body N/A
Frame
  • Frame Type N/A
  • Sect Modulus Rails Only N/A
  • Frame RBM N/A
  • Frame Strength N/A
  • Frame Thickness N/A
Fuel Tank
  • Fuel Tank Capacity, Approx 18.8
  • Aux Fuel Tank Capacity, Approx N/A
  • Fuel Tank Location N/A
  • Aux Fuel Tank Location N/A
Interior Dimensions
  • Passenger Capacity 8
  • Front Head Room 39.5
  • Front Leg Room 41.4
  • Front Shoulder Room 61.6
  • Front Hip Room 58.9
  • Second Head Room 40.2
  • Second Leg Room 42.4
  • Second Shoulder Room 59.9
  • Second Hip Room 58
  • Third Head Room 38.1
  • Third Leg Room 31.4
  • Third Shoulder Room 55.3
  • Third Hip Room 43.7
Mileage
  • EPA Fuel Economy Est - Hwy 24
  • Cruising Range - City 357.20
  • EPA Fuel Economy Est - City 19
  • Fuel Economy Est-Combined 21
  • Cruising Range - Hwy 451.20
Steering
  • Steering Type Rack-Pinion
  • Steering Ratio ( :1), Overall N/A
  • Steering Ratio ( :1), On Center N/A
  • Steering Ratio ( :1), At Lock N/A
  • Turning Diameter - Curb to Curb 19.4
  • Turning Diameter - Wall to Wall N/A
Suspension
  • Suspension Type - Front Strut
  • Suspension Type - Rear Multi-Link
  • Spring Capacity - Front N/A
  • Spring Capacity - Rear N/A
  • Axle Type - Front Independent
  • Axle Type - Rear Independent
  • Axle Capacity - Front N/A
  • Axle Capacity - Rear N/A
  • Axle Ratio ( :1) - Front 3.65
  • Axle Ratio ( :1) - Rear 3.65
  • Shock Absorber Diameter - Front N/A
  • Shock Absorber Diameter - Rear N/A
  • Stabilizer Bar Diameter - Front N/A
  • Stabilizer Bar Diameter - Rear N/A
Tires
  • Front Tire Size P245/60TR18, P245/50TR20
  • Rear Tire Size P245/60TR18, P245/50TR20
  • Spare Tire Size Compact
  • Front Tire Capacity N/A
  • Rear Tire Capacity N/A
  • Spare Tire Capacity N/A
  • Revolutions/Mile @ 45 mph - Front N/A
  • Revolutions/Mile @ 45 mph - Rear N/A
  • Revolutions/Mile @ 45 mph - Spare N/A
Trailering
  • Dead Weight Hitch - Max Trailer Wt. 5000
  • Dead Weight Hitch - Max Tongue Wt. 500
  • Wt Distributing Hitch - Max Trailer Wt. 5000
  • Wt Distributing Hitch - Max Tongue Wt. 500
  • Maximum Trailering Capacity 5000
Transmission
  • Drivetrain All Wheel Drive
  • Trans Type 8
  • Trans Description Cont. Automatic w/OD
  • First Gear Ratio ( :1) 4.81
  • Second Gear Ratio ( :1) 2.90
  • Third Gear Ratio ( :1) 1.86
  • Fourth Gear Ratio ( :1) 1.42
  • Fifth Gear Ratio ( :1) 1.22
  • Sixth Gear Ratio ( :1) 1.00
  • Reverse Ratio ( :1) 3.42
  • Clutch Size N/A
  • Trans Power Take Off N/A
  • Final Drive Axle Ratio ( :1) N/A
  • Transfer Case Model None
  • Transfer Case Gear Ratio ( :1), High N/A
  • Transfer Case Gear Ratio ( :1), Low N/A
  • Transfer Case Power Take Off No
  • Seventh Gear Ratio ( :1) 0.80
  • Eighth Gear Ratio ( :1) 0.65
  • Weight Information
  • Standard Weight - Front 0
  • Standard Weight - Rear 0
  • Gross Axle Wt Rating - Front N/A
  • Gross Axle Wt Rating - Rear N/A
  • Curb Weight - Front N/A
  • Curb Weight - Rear N/A
  • Option Weight - Front 0.00
  • Option Weight - Rear 0.00
  • Reserve Axle Capacity - Front N/A
  • Reserve Axle Capacity - Rear N/A
  • As Spec'd Curb Weight N/A
  • As Spec'd Payload N/A
  • Maximum Payload Capacity N/A
  • Gross Combined Wt Rating N/A
  • Gross Axle Weight Rating N/A
  • Curb Weight N/A
  • Reserve Axle Capacity N/A
  • Total Option Weight 0.00
  • Payload Weight Front 0
  • Payload Weight Rear 0
  • Gross Vehicle Weight Rating - 5776.00 LX, 5917.00 EX, 5736.00 SX
Wheels
  • Front Wheel Size 18 X 7.5 - 20 X 7.5
  • Rear Wheel Size 18 X 7.5 - 20 X 7.5
  • Spare Wheel Size Compact
  • Front Wheel Material Aluminum
  • Rear Wheel Material Aluminum
  • Spare Wheel Material Steel
