Little China
#34
Those Black Rhinos are slick. I’m definitely considering a set of those to replace my EX wheels. I’ve been holding out so far to see what Tirerack will have available. I’m a little surprised that they don’t have their wheel selection available already for the Telluride.
I've been checking every other day too. I think their wheel selection will be similar to that of the Sorento.
#36
So instead of their usual "Market Adjustment" of 5 or 10K Kia of Cerritos can tack on another 2K for the new wheels?
#38
If doing 22", tire circumference may be different which will affect speedometer accuracy. The factory 18 and 20 " wheel/tire set up has the same circumference so no effect on a swap. Maybe
@StephenCantrelle has a dealer response on effect of the 22", if any.
As long as the overall diameter is relatively the same you should be fine. With 22" you'll just have to run lower profile tires.
