Infotaiment system update
Calgary, AB, Canada
Have you tried using the desktop application yet? The reason I ask (and I'm unsure if this is the case for our system or not), is that with many manufacturers, their desktop application that's used to download the content updates provides access to the geographic specific content based on IP (or in some cases, VIN0 information. I would just run the application and see what it provides access to. Since you're just downloading material from the web onto a USB stick that you would then use to update your vehicle's system, there's no risk other than some time spent to test the process.
