High Beam Issues
First Kia
Pennsylvania
Has anyone had issues with the Telluride high beams burning out? The high beams on our EX stopped working so I took it to the dealer. They said the bulbs were burned out and replaced them. Tech turned on the high beams and and both burned out immediately. Dealer can't figure it out and have to go back again.
Are you talking about a SX?
The bulb used on the EX does not have a “high-beam” filament. High beam is turned ON by mechanically raising the “shield” within the projector assembly.
The dealers should know this!
ERNYSAN
If they told you that they are lying you. One single bulb with one single filament low/hi beam are activate by the head lamp mechanism so if you have no High beam more like you have a bad headlamp assy or short somewhere on the assy
