Engine Noise on Startup
Do you have engine rattle on cold startup?
  • Yes
    Votes: 4 50.0%
  • No
    Votes: 4 50.0%
  • Total voters
Does anybody else have the engine rattle on startup? I read some issues in the past with the 3.8 timing chain tensioners, so was surprised that on the 2020 Telluride, I heard the startup noise. Please chime in/vote. It only lasted for about 1 second, but was definitely noticeable outside the car.
I get a very slight and very quick noise on starting, but goes away within seconds. I had the same thing with my Toyota Highlander. I believe it is normal.
Kelowna, BC, Canada
This is a new 3.8l designed differently
from old 3.8l. I dought very much there is an issue with the timing chain tensioner.They had timing chain tensioner issues in the past with the 3.3 l as well, 2007- 2008. The 3.8 and 3.3 has had major redesign as they are used in the Genesis Luxury vehicles as well. I'm glad that they didn't use the Turbo version in the Telluride!
rigogs
Texas
Our 2023 gas engine rattles when cold for about 30-60 seconds, we can hear rattle in mornings after tensioner releases chain pressure and it goes away when enough oil press. adjusts.
A clip on tensioner is supposed to keep plunger from retracting, rattle sounds as if we had a diesel, my guess it does not damage eng. if one waits or drives away slow.
Will talk to KIA dealer, may have to leave it overnight, and of course they will want their diagnostic fee.
