Are the wheel pattern and offset on the Telluride the same as the Sorento?
Tennessee
I want to put 20's on my EX, what specs do I need to look for?
Bolt pattern 5x114.3 or 5x4.5
Wheel size 20 x ?
Backspace ?
Offset ?
Hub bore: ?
Wheel size 20 x ?
Backspace ?
Offset ?
Hub bore: ?
https://www.discounttiredirect.com/ and select 20" wheels for the Telluride. You'll find that the offsets will average around +40 depending on how wide you go. OEM bore hub is 67.1, most aftermarket bore hubs are larger to be a universal fit. You'll need hubcentric rings.
