Engine lifespan
Kelowna, BC, Canada
#21
I use Top Tier gas only should I go back to 87 with e10 or mid grade 89 with e5 or 91 with 0 ethanol. Dealer recommend 6,000 Km oil change as opposed to 12,000 Km according to the owners manual.
Spoke to my dealership mechanic today. The reason for the severe use maintenance service is due to my use and location's type of weather. They use Castrol Edge full Synthetic oil between every 6,000 to 8,000 Km and at every 32,000Km they do an Upper Cylinder pressure clean with the engine running for an extra $150.00 which takes about 3/4 to 1 hr. I did some research and found this maintenance would keep the engine running at optimal efficiency and longevity. This would take care of the inevitable carbon build up on the intake valves therefore eliminate potential problems or possible engine damage due this carbon buildup . This problem is with ALL Direct Injection engines. So you pay now or pay a lot more later!!!
GNR
Canada
#23
let me put it another way, my Telly 8s my 5th Kia and change oil @ 7500 miles and have 32,000 trouble free miles so far. Had '07 sorento that currently has 345,000 miles and still runs as goot as it did new (gave to my dad) he is still driving it and it has never had any engine issues or been on shop for repairs. Had '14 sorento with 300,000 miles with no engine issues or repairs (traded on Telly) but still ran great. Also have '12 & '13 forte's with over 70,000 on each with to troubles with either. All Kia's changed @ 7500 miles with Mobile 1 full synthetic in '07 and Pennzoil Ultra Platinum full synthetic in others. None have been in the shop for engine repairs
Sounds like the V6 Kia's are good for a lot of miles (at least the port injection ones).
GNR
Canada
#25
I wonder if an Atkinson cycle engine like the Telly's would have less problems with carbon build up?
As I understand it, some unburnt fuel is pushed back past the intake valve before it closes with an A cycle engine. That fuel might help to clean carbon deposits?
Kelowna, BC, Canada
#26
It does help somewhat but not to the extent that some will make you believe. That statement is according to my automotive engineer friend.
Rick2456
Charleston, SC, USA
#29
Most Gas Direct Injection engine will have a short life expectancy due to Intake valve deposit. My 2020 3.8l Telluride has very heavy carbon deposit at the tail pipe and my gas mileage has dropped at 2,245Km or 1,394miles. I will probably have the valves cleaned every 12,000miles using a DGI spray cleaner. I use Shell mid-grade gas and Castrol Synthetic oil. I think Hyundai and Kia should have both DGI and Port Injection were several manufacturers have started to use in 2019.
My 22 telly hasn't had any issues and I do keep on top of the oil consumption (none) and the tailpipe (clean). But I do change the oil every 5k and use only top tier gas. So far, so good.
Dave B
High Desert, Southern California
#30
Hello. So I have been doing some research and the following website explains the: performance and pros & cons of the Telluride engine. NOTE: the Lambda 3.3L, 3.8L, etc are in the same family. It states the engine has a life expectancy of 180,000 miles but can be as low as 150,000 🤔. I have 159k on my current vehicle. I tend to keep my cars for awhile.
What are your thoughts on the engine life expectancy OR experience with a Kia vehicle hanging on for the long haul? Thanks in advance.
Hyundai KIA 3.3L Engine (Lambda MPI/GDI/T-GDI) specs, problems, reliability, oil, Santa Fe, Stinger
http://www.motorreviewer.com/engine.php?engine_id=141
I'm a newly purchased used 2020 KIA Telluride owner who based his purchase decision on experience with virtually the same 3.8L engine installed in my KIA 2017 Sorento. That car was totaled in a non injury accident cause by a double trailered rig pealing off the side of that car. At the time of that accident the engine/car had recorded 215K miles of uneventful use with an initial set of plugs changed at 120K miles. I was getting a combined city-road mileage when the accident occurred of 26.5/gal. We live in the high desert north of Los Angeles operating the vehicle with the lower air density found at 3000 ft. above MSL with temperature variations from the mid 20s to 110 F in the summer.. Our usage averaged 25,500 per year with much high speed (think 75 MPH) drive on LA freeways. We used non-detergent gas nearly 100% of the time.
So what do I attribute what many would say is my good luck. First is my switch to 100% premium synthetic oil at about 75K miles with regular oil-filter changes at 7K. Second the use of detergent injector and valve cleaners every 5K or so. This is a must when using non-detergent gas. One issue did arise around 185K miles. I started to get knocking within the catalytic converter assembly. The use of a special detergent targeting the oxygen sensor and the convertor itself (or so I was told) cured the problem immediately, a $30 fix. Finally, I have an excellent set of local mechanics who tended to that car. KIA only saw it once in it's life time and that was to replace the battery under the new car warrantee (partial coat reduction).
So why did I go to the Telluride? Well my wife voted for more interior room. I like some the added safety features we got with the Telluride. We shall see over the next year or so. I will be adding injector cleaner to the gas today to our just recently purchased Telluride. Wish us good luck!
