Parking brake sticking issue caused by Recall SC303
d2s11
Stevensville, MI 49127
Recall SC303 (driveshaft issue) is supposed to prevent your Telluride from rolling away while in Park by automatically engaging the parking brake every time the engine is turned off. Unfortunately, this cheap fix creates a side effect. The brakes will stick whenever the car is driven in wet conditions and then parked for more than a couple days. In fact, it will even happen in conditions of high humidity. It doesn't take long for a little rust to develop and cause the problem. This has happened to my Telluride several times now since Recall SC303 was performed. I tried to avoid this by releasing the brake after parking, but unfortunately the software upgrade does not allow it. Kia needs to fix the real problem with the driveshaft and not mess with the operation of the parking brake. It will be interesting to see what happens this winter when the brakes are sticking not only from rusting, but also from freezing.
Hackettstown, New Jersey
This was posted by another owner, see if it helps with your issue:
" The EPB will automatically engage when you shot off the vehicle. Not too much of a concern for me being in Texas, however there is a workaround. If you press and hold down on the EPB button and then turn off the engine it won't engage. Tried this on mine and the EPB was off when restarting the vehicle. "
kim31
illinois
I had recall sc303 done 2 weeks ago and live in a cold climate where we've had snow and ice the past 2 weeks. Guess what has happened? The brakes have stuck numerous times. One time backing out of my garage the noise of the brakes releasing was so loud I thought I'd run something over. Occasionally they sound like they are grinding even when I'm driving. This is not an acceptable fix. Now that I've read the work around I will be doing that every time.
D
d2s11
Thread Starter #4
Yes, I appreciate the input on the workaround. I use this now with success, but often times I forget. I've been driving for many years and had no problem with parking brakes until this came along. Some progress by our manufacturers and NHTSA.
