No experience here - but info for you... FWIW
Need to be sure the tire will work with the rim width, and note that the revs per mile are different
Here are the specs for the stock wheels...
7.5" wide by 18" dia with a 49.5mm positive offset
bolt pattern 5 lugs on a circle diameter of 114.3mm
Thread size is 12mm x 1.5mm
Center bore is 67.1mm
Here are some basic tire specs - need to verify with your actual tire brand
