CA
#81
Ok does the rim width matter? The rim I'm buying is 20x8 and the stock 20 is 20x7.5
CA
#82
Also is there such a thing as a bolt mod applicator? The bolt pattern on the Kia is 114.3 the rims I like are 5x120 is there a converter to buy??
telluride
Thread Starter #83
Wheel width does matter, you can use 20x8.
They sell adapters but they work like wheel spacers, this means you'll have to find a more narrow wheel. If you want the best fitment just stick with the proper wheel pattern.
CA
#84
Ya you're right, i found a 20x8 ill just get those :)
telluride
Thread Starter #90
Question , will these fit with the 32 offset ? Rears would run 20x9 and fronts 20x8.5
Being that the Telluride is AWD, I'd go with 20x8.5 all around. I called Discount Tire and they suggested wheels with +35-40mm offset so that it wont rub. That said I think you should be fine with 32mm at 20x8.5, worst case scenario is that you might need a more narrow tire.
CA
#93
Lots of new black options on line. Probably cheaper than paying extra to powder coat black. Example : Helo 894
Yes but with a high price tag aswell lol
These are second hand for 400cad
I'll be painting them in plastic dip myself
CA
#96
Wheels arrived today!
They had a bit of curb rash.. so I think I'm going to be repainting completely.
Doing some metal and edge corrections and spraying a gloss black.
