7,500 mi.
Replace
- Rotate tires
- Engine oil and oil filter
- Climate control air filter
- Fuel additives
- Brake fluid
- Tire (pressure and tread wear)
- Parking brake
- Brake discs and pads
- Air conditioner compressor/refrigerant
- Air cleaner filter
- Bolt and nuts on chassis and body
- Vacuum hose
- Battery condition
- Steering gear rack, linkage and boots
- Brake lines, hoses and connections
- Suspension ball joints and mounting bolts
- Exhaust system
15,000 mi.
Replace
- Rotate tires
- Fuel additives
- Fuel tank air filter
- Brake fluid
- Fuel lines, hoses and connections
- Vacuum hose
- Battery condition
- Exhaust system
- Parking brake
- Drive shaft and boots
- Vapor hose and fuel filler cap
22,500 mi.
Replace
- Rotate tires
- Fuel additives
- Exhaust system
- Brake fluid
- Parking brake
- Vacuum hose
- Battery condition
30,000 mi.
Replace
- Rotate tires
- Fuel additives
- Brake fluid
- Parking brake
- Cooling system
- Vacuum hose
- Battery condition
- Exhaust system
37,500 mi.
Replace
- Rotate tires
- Fuel additives
- Rear axle oil (AWD)
- Transfer case oil (AWD)
- Brake fluid
- Brake fluid
- Exhaust system
- Vacuum hose
- Battery condition
45,000 mi.
Replace
- Rotate tires
- Fuel additives
- Brake fluid
- Parking brake
- Cooling system
- Vacuum hose
- Battery condition
- Exhaust system
52,500 mi.
Replace
- Rotate tires
- Fuel additives
- Brake fluid
- Parking brake
- Vacuum hose
- Battery condition
- Exhaust system
60,000 mi.
Replace
- Rotate tires
- Fuel additives
- Drive belts
- Valve clearance
- Exhaust system
- Vacuum hose
- Battery condition
- Brake fluid
- Parking brake
- Cooling system
67,500 mi.
Replace
- Rotate tires
- Fuel additives
- Exhaust system
- Vacuum hose
- Battery condition
- Parking brake
- Brake fluid
75,000 mi.
Replace
- Rotate tires
- Fuel additives
- Drive belts
- Brake fluid
- Parking brake
- Cooling system
- Vacuum hose
- Battery condition
- Exhaust system
82,500 mi.
Replace
- Rotate tires
- Fuel additives
- Vacuum hose
- Battery condition
- Exhaust system
- Brake fluid
- Parking brake
90,000 mi.
Replace
- Rotate tires
- Fuel additives
- Drive belts
- Exhaust system
- Vacuum hose
- Battery condition
- Cooling system
- Parking brake
- Brake fluid
97,500 mi.
Replace
- Rotate tires
- Spark plugs
- Fuel additives
- Exhaust system
- Vacuum hose
- Battery condition
- Parking brake
- Brake fluid
105,000 mi.
Replace
- Rotate tires
- Fuel additives
- Drive belts
- Cooling system
- Parking brake
- Brake fluid
- Vacuum hose
- Battery condition
- Exhaust system
112,500 mi.
Replace
- Rotate tires
- Fuel additives
- Vacuum hose
- Battery condition
- Exhaust system
- Parking brake
- Brake fluid
- 3
- Show All
