Did you follow the Lasfit video or do you use a less invasive method? Any special tips or tools used?
Successful upgrade this weekend on my 2022 SX Prestige Nightfall Wolf Grey over Dune, tow and LED interior lights. Only mod so far has been the KIA badge blackout decal.
Replaced license plate halogens with Lasfit 194 168 2825 W5W LED (T10 compatible). Wires to bulb fixture too short to get my fat fingers around it so I had to use needle nose pliers to unscrew from lens. Took about 20 minutes total.
Then I took the plunge and did the rear backups. Purchased the Sunplustrade Auto Trim Removal set on Amazon for $10. You will need the thin needle like tool to create a gap to then fit the wide pry tool into position. I recommend you watch the Lasfit video multiple times, before and during the install, and pay attention to the subtle details of the disassembly and reassembly. Once you get the large rear piece off, you will find the video doesn't show that the rear hatch close button
stays on the panel and hangs from the wire! I had to use my rolling worktable to support the entire panel and keep tension off the wire. Also be ready for the hatch to try to close as you manipulate the panel/close button. I took pics of the inside of the panel so I had a better idea where to later direct my hand thumps to seat the panel back into place. I used Auxito 912 921 LED (T15 compatible). Took about 45 -60 mins. Wasted 15 mins trying to locate where a small broken plastic piece came from when the large panel popped off...never found the origin so I figured it was leftover from factory assembly. Wife took pity on me and agreed to put the Telly in reverse during the install and at completion to confirm correct function lol. No error codes or hyperflash!
Thanks to all who have posted before and have answered my questions!
