Black out grill?
CA
Hey guys I'm contemplating having g the front grill and "TELLURIDE" dipped black.
Jas any one done this yet?
Tennessee
I'm going to black out the two pieces above and below in a wrap. And other parts. Ill post pictures when I get them finished. There was one photo on here somewhere that everything was black out and matted, trying to find it again. It looked sharp!.
italsal
CA
Awesome! Ya I was alsonthingjng the top and bottom gloss and the midsection matte
italsal
CA
So how does one go about dipping the lettering themselves? What the process? Is it done while the letters are still on the vehicle or are they removed for the applicaiton of the dip ?
You can mask off the car and isolate just the parts you want dipped. You want to leave about half inch around the part. When plasti dip cures/ drys it turn to rubber. You can roll it and peel the excess...
I can create a how to when I do it?
I've never done it but the results are pretty cool looking for sure. How does plasti-dip hold up to winter weather?
italsal
CA
Thread Starter #12
Not bad. The key is layers!
I did my winter wheels on my s4 and sprayed 7 layers. In order to easily remove it..
Chicago, IL, USA
NICE! For the grille, did you remove it from the vehicle or did you leave it on and mask it? I haven't dug too deep yet, but it looks tricky to remove it so far. If you did remove it, could you provide any tips? Thanks much.
Thanks! However, I'm trying to remove the grille in order to dip the entire thing black. I found an old article about removing a grille on a Sorento, maybe it will be the same or similar on the Telly: https://www.kia-forums.com/threads/...-replacement-blackout-grill-plastidip.137905/
Chicago, IL, USA
Did u plastidip that yourself
Finally had some time to dip my Telly grille! I saw a video on YT of a guy applying the dip with the grille still on his vehicle, so I said why not vs. remove the grille, dip, reinstall. So, here’s what I did in a nutshell:
First I removed the badge, was pretty easy. I used a tool for bicycle tube installs, worked perfectly and popped off safely.
Then I masked near the grille edge and then used newspaper to mask the front end off. After all of it, I still had some minor overspray so heads up on that. No biggie, it wipes off easy.
Next I sprayed a light first coat. I don’t like chrome so I did the entire grille. After 30-40 min Each coat, I did some heavier applications while keeping it nice and even.
Lastly I snapped the badge back on, pulled the masking tape off and pulled off the excess dip.
Here’s some detail shots, I’ll post a bit further away pic tmrw. Sorry, my garage is a wreck right now haha.
